Exception in java
krishbcs
@krishbcs-5tG26c Oct 22, 2024
Exception has two types. Unchecked Exception and Checked Exception.
IOException
ClassNotFoundException
CloneNotSupportedException
IllegalAccessException
InterruptedException
NoSuchFieldException
NoSuchMethodException
These are Checked Exception.
Can you explain each exception with simple example(Error program and correction program)?
    @anoop-kumar-GDGRCn Feb 22, 2012
    Checked Exception: You must have to handle those exceptions by yourself using try-catch or throws clause
    Unckecked: JRE will take care of these things
    Why Checked Exception: In case of IOException, for example you wrote a program to read a file. How can java know if file is there to read? that is why it insist you to catch this exception by yourself.
    Java is telling you that somewhere it could be wrong.
    Rest, explaining each exception will be a theory , I would suggest you to write programs in which these exception can occur. If will give you live practical example.
  • krishbcs
    @krishbcs-5tG26c Feb 23, 2012
    ianoopChecked Exception: You must have to handle those exceptions by yourself using try-catch or throws clause
    thanks but i need detail each exception with examples.
  • krishbcs
    for example:
    ArithmeticException:
    Error program:
    class ArithException
    public static void main(String arg[])
    System.out.println(2/0);
    Output: ArithmeticException Error.
    Correction Program:
    try{
    }catch(ArithmeticException)
    { System.out.println("divide by zero is not valued");
    Ouptut: Divide by zero is not Valued.
    I need like this for every exception.
    would you help me?
