Essar Placement Paper Questions with Solutions
Paper I-
1. SQRT (156.25) * SQRT (14.25) = 35 * X what is the value of X? X = 1.25
2. A + 8450 ÷ 650 = 13 + A. What is the value of A? A = 0
3. The sum of a number whose ? th is 45. What is the number? Ans: None
4. The sum of a 2 digit number is equal to the difference between them. Find how many such numbers are possible? Ans: 10
5. The sum of a 2 digit number is equal to twice the difference between them. Find how many such numbers are possible?
6. 1000.01 – 100.01 – 10.01 = X. what is X? X = 889.99
7. 0.25% of 10 – 10% of 0.25 = 25% of 100 – 100% of X. What is X? X = 25
8. One – fifth of two – third of a number is equal to 24. What is the number?
9. 100$8 – 2$39 = $319. What is $? $ = None of these
10. Ajith and Ajay’s age are in the ratio of 3:5. Two years hence, their age are in the ratio 7:11. What is Ajith’s present age? Ajith’s age = 12.
11. The length of a train is 200m and it crosses a platform of 75m in 15sec. Another train with a length of 180m which is on the opposite direction approaches it. How long it will take to cross the other?
12. (X) – Square, % - Square root, # - Divide, * - Multiply, @ - addition and & - Subtraction. Find the value of (4)#4%4*4@4
13. Solve 30 – 0.05 *20 +10÷ 5 =?
14. A circle of diameter 28 cm. If there is a rectangle of length 56 cm. What is the value of breadth whose areas are equal? Breadth = 44cm
15. A wheel rotates 18 revolutions in 4.5 sec. What are the revolutions of the wheel per minute? Revolutions = 240
16. Solve: 20% of 60%of a number is equal to 40% of 200. What is the number?
17. 252 x 253 =? 252 + 3
18. Series: 5 5 7.5 15 37.5 112.5 339.75 X
19. Trisha’s monthly salary is 25% more than Krishna’s salary but 25% less than Payal’s salary. Krishna’s annual income is Rs. 1, 20, 000. What is the monthly income of Payal?
20. There is a seven consecutive odd numbers. What is the number greater than 6 and it is smaller than 6?
21. Work done is Zero for which process?
Ans: Constant Volume
22. Which cycle has high efficiency?
Ans: Otto Cycle
23. The power of 2 –stroke engine varies from 4 – stroke engine by______.
Ans: Twice
24. Sudden reduction in barometer leads to ______.
Ans: Storm
25. Composition of Stainless steel ____.
Ans: Chromium, Nickel …
26. Gears are produced in mass production by ______.
Ans: Hobbing
27. Pick out the wrong statements:
a) The good fuel should have high calorific value
b) Ease in storing
c) High ignition point
d) Low smoke and gases
Ans: (C)
28. Composition of Gun metal _____
29. Gears are commonly called with _______
Ans: Pitch Circle Diameter
30. A good fuel should have ________ ignition point.
Ans: Low
Paper II-
1. If heat supplied into the system is 30000 J/S and the power output is 9KW. What is the efficiency of system?
2. A square rod of 2cm x 2cm of which a force of 8800Kg is acting on it. What is the stress developed in it?
Ans: 2200 Kg/cm2
3. GNATT chart shows___________
4. Which is the high efficiency freezing agent?
Ans: Freon 22
5. Property of the freezing agent is: Ans: Low boiling point and high melting point
6. A diesel engine, that is, slow speed engine follows which cycle? Ans: Diesel Cycle
7. Hardness is the property of _________.
8. A Rotary compressor depends on ___________.
9. The potential energy raised upwards ___________ the kinetic energy downwards. Ans: is equal to
10. Centipoise is the unit of ________.
Ans: Dynamic Viscosity
11. For a thermodynamic system, the COP is 5 and the heat supplied to the system is 1 KW. What is the work done?
12. In an ideal gas compared to a real gas at very high pressure occupies?
13. Kinetic theory of gases assumes that collisions between the molecules are?
14. The condition of perfect vacuum that is at absolute zero pressure can be attained at?
15. Specific heat of air?
16. Which law states that internal energy is function of Temperature?
17. Minimum work done for an adiabatic process the value of n?
18..Air Refrigerator works on?
1 watt = 1Nm/S
1 h.p = ?kw
19. When crude oil heated Which Hydro carbon comes first?
20. What is the purpose of Supercharger?
21. 1Kg of carbon to CO, Amount oxygen required?
22. Horse power per tones of refrigeration?
23. Scale formation on the surface of the boiler tubes due to ?
24. Axial shift in steam turbine occurs due to?
25. Latent heat of vaporization at low pressure and temperature?
26. Shaft revolving in a bearing which pair?
27. Difference between dedendum and addendum?
28. The fatique life of a part can be improved by ?
29. Rotational tendency of force?
30. Acetylene dissolved in ?
