Engineering Project Help - LDR security buzzer circuit
Hello there
I was woundering if anyone would be able to point me in the right direction with my project for college.
I am doing a simple buzzer circuit using a light dependant resistor, 9v battery, BC639 transistor, a 1k resistor, a 10k resistor and a switch.
I am mounting the components inside a enclosure with the switch and the ldr exposed on the outside. My idea behind it is to be used in a safe for security, so when the door is opened the buzzer sounds due to exposure to light.
The concept im having difficulty with is finding a way to add some sort of button password combination in replacement of the switch, so that when the owner of the safe was to open it they could deactivate the buzzer and then activate it again after use.
Im really no expert on this so go easy with me please
Thank you
Thank you
