  • gohm
    @gohm-F3UUpP • Aug 25, 2009
    It will vary a bit depending on the specific engine & wether you are converting a gas or diesel motor. There is a lot of info on the net. Many companies sell conversion kits. You will be modifying the injection system, timing as well as fuel storage. You may require cylinder/head work. Diesels will require compression ratio modification as well as spark. You can also run a dual setup.
