  • encryption project
    jmulopa
    jmulopa
    @jmulopa-CgAmou
    Updated: Oct 26, 2024
    Views: 1.1K
    Source code for AES and Twofish in Java project
    I need source code (JAVA) and gui to encrypt using AES and Twofish and also use the mouse movements to seed.
  • PraveenKumar Purushothaman
    MemberMar 9, 2011
    jmulopa
    i need help on an encryption project for my undergraduate program. below are some of the aims of the project. It has to be coded in java or any othe language. I would appreciate directions on how to do it from GUI to coding
    1. System should allow user to enter message and select an encryption algorithm (AES,DES,RSA, Blowfish etc and own algorithm)
    2. use java applets or as a standalone
    3. use symetric or asymmetric keys
    4. When encrypting be able to split a file into chunks and encrypt individual chunks using same key or increments of same key or use of salt
    5. Encrypt a folder, file, or harddrive
    6. shred a source file after encrypting
    7. menu should offer compression and emailing of file
    The project is simple and easy... Can you please introduce yourself in the CE Introductions???
    By the way, you can implement using the Java AWT...
  • Koradiya Abhay
    MemberJan 24, 2016
    Praveen-Kumar
    hello praveen kumar can you give me your encryption project code?
