  • Emergency: Tell me the torque required
    ajitishere
    Member
    Updated: Oct 26, 2024
    Views: 1.1K
    Can anyone tell me how much torque is required to rotate the steering of a car which has no power assist in running and stationary conditions???....
    this is an emergency...
    I need to know it as soon as possible..The car is a Maruti 800(Old one 96 model)
  • gohm
    MemberNov 26, 2009
    The formula will be your basic torque solution. There is a couple other threads about torque that might help you get started. You will need to know the gear ratio of the steering, weights, friction, etc. What have you figured out so far? Is this for a class?
  • ajitishere
    MemberNov 26, 2009
    gohm
    I wanna do a project for 4th year BTech where I have to use stepper motors to rotate the steering wheel of a Maruti 800.. If I would have known the torque, it would have been easier for me to find out the torque requirement of the motor I should use..
    If you or anyone can help, please do.
  • gohm
    MemberNov 27, 2009
    Due to variations inherent in manual steering forces(plus the vehicle), you will need to fabricate a jig that will read using a torque gauge.
  • ajitishere
    MemberNov 28, 2009
    Can you or anyone give just an approximation on how much torque will be required, please?
    I am desperate
    I have no time to use any measuring device to measure and also finance is a problem..
    Kindly help
  • gohm
    MemberNov 29, 2009
    Unfortunately we cannot as you are missing several key data variables as I mentioned previously. Building a rig to measure the torque can be done very cheaply. If you have no time to use a measuring device to get the basic data then your only option is to contact the manufacture to see if they can supply you with the information.
