Electro static pracipitator required power calculation?
Sagar Jiyani
@sagar-vSGxut โ€ข Oct 26, 2024
i m from engineering firm.
in india there is above 7 tph boiler used ESP for dust remove from flue gas.
if i want to make esp for 1 to 6 tph boiler then what should be T-R set spesification? watt? voltage? etc.
    @ramani-VR4O43 • Mar 13, 2019
    I had designed an ESP system for precipitating talcum powder dust from an equipment that was used to apply this powder on rubber gloves. Since the volume was quite small very little wattage was needed. You can check this nptel lecture:
    Commercial precipitators are available for various capacities.
  • Sagar Jiyani
    @sagar-vSGxut • Mar 27, 2019
    SIR CAN YOU GIVE ME THE T-R SET DETAIL FOR 2 TPH BOILER ESP?
    @ramani-VR4O43 • Mar 28, 2019
    Such detailed engineering is beyond the scope of this site.ย
    Someone may perhaps be able to help.
  • Sagar Jiyani
    @sagar-vSGxut • Mar 28, 2019
    Ok sir..thnks..
    <a href="https://www.google.co.in/search?q=t-r+set+for+electrostatic+precipitator&ie=UTF-8&oe=UTF-8&hl=en-in&client=safari" target="_blank" rel="nofollow noopener noreferrer">t-r set for electrostatic precipitator - Google Search</a>
