Electrical Engineering interview questions..
ivenkii
ivenkii
@ivenkii-hTLR2P Oct 26, 2024
Hi guys,
I have attended a interview where they have asked me few questions, I need to know some...
1. what is the different between CGS system and MKS system?
2. When we connect the capacitor Banks in Series with the circuit?
3. What is the difference between Earthing & grounding?
4. how much voltage is present in neutral resistance?and how much voltage is present in earth resistance?
5. What is the purpose of calculating knee point voltage for Current transformers?
Awaiting your answers..
  • Jackson44
    Jackson44
    @jackson44-VzZHyR Apr 21, 2010
    Hi ivenli,
    Thank you for posting these questions...
    ----------------#-Link-Snipped-#
  • jerryvn01
    jerryvn01
    @jerryvn01-cxfPwe Jul 22, 2010
    Jackson44
    Hi ivenli,
    Hi,
    I agreed with you. Any way, your ideal make me thinking about some thing for my project.
    [FONT=&quot]Apart from that, this link below may be useful: [/FONT] #-Link-Snipped-#
    [FONT=&quot]Please try to keep posting. Tks and best regards[/FONT]
  • raghunathreddy36
    raghunathreddy36
    @raghunathreddy36-FhZFqH Jul 23, 2010
    good you are answered these questions
  • vasanthmbs
    vasanthmbs
    @vasanthmbs-3fG5UO Jul 24, 2010
    2) to reduce capacitive reactance in the line
    3) sorry .. i think both are same .. may be the question will be diff b/w neutral and earthing ???
    4)voltage in neutral is zero
  • raghunathreddy36
    raghunathreddy36
    @raghunathreddy36-FhZFqH Jul 24, 2010
    i also attend the my interview questions
    1.if the diesel generator capacity 50kva but we are loading 20kva, suddenly the DG load increases suddenly 10-20kva what happens?
    2.in power plant how much pressure in boiler
    pls answer this questions
  • bhagi13
    bhagi13
    @bhagi13-NCWr28 Jul 25, 2010
    1. Both CGS n MKS are measuring standards. In CGS system, length is measured in Centimeter, weight in Grams and time in Second.
    In MKS, length is in Meter, Weight is in Kilogram, and time is in Second.
    2. we r connecting capacitors bank in series with circuit to
    a) To remove the low frequency noise signal,
    b) To decrease the capacitive impedance.
    3. earthing means providing low impedance path to the circuit. And earthing wire is always ends in earth surface. Grounding means proving a Zero reference level to whole circuit or system. With reference to ground level, voltage at other nodes is measured.
    @thebigk Nov 12, 2016
    i have a blog that will surely help you....go there
    jobsoxt.com
    go here for more #-Link-Snipped-#
