effect of valve diameter
mechky
@mechky-jbqpJD โ€ข Oct 21, 2024
Does anyone know the effect of inlet & exhaust valve diameter on the engine performance?
What will happen if both the inlet & exhaust valve diameter is decreased maintaining the same initial ratio? What parameters of engine will change?
  • CE Designer
    @ce-designer-BWq0yl Jan 3, 2012
    Diesel or petrol engine?
  • mechky
    @mechky-jbqpJD Jan 3, 2012
    CE DesignerDiesel or petrol engine?
    petrol engine
  • Siddhant Mukherjee
    @siddhant-4mGRnx Jan 3, 2012
    Decreasing valve dia upto a certain limit will increase engine performance of petrol engine . This is so because as valve dia dec. , the pressure of charge at inlet manifold will decrease due to increase in flow velocity. This will result in decrease in temperature of charge, reducing chances of preignition and knocking. So you can easily increase the compression ratio resulting in more power output in same fuel consumption... Thus bsfc increases. The efficiency also increases as a result .
    Decreasing the dia too much will result in problems bcoz the charge temp will dec. too much making it difficult for fuel to reach its self ignition temperature.
  • mechky
    S.mukherjeeDecreasing valve dia upto a certain limit will increase engine performance of petrol engine . This is so because as valve dia dec. , the pressure of charge at inlet manifold will decrease due to increase in flow velocity. This will result in decrease in temperature of charge, reducing chances of preignition and knocking. So you can easily increase the compression ratio resulting in more power output in same fuel consumption... Thus bsfc increases. The efficiency also increases as a result .
    So, it probably means that whatever engines are manufactured their valve dia is already upto that 'certain limit' of getting maximum engine performance.
    Correct me if I am wrong.
  • CE Designer
    Less fuel = Less compression = less power
  • mechky
    CE DesignerLess fuel = Less compression = less power
    I seriously doubt that. Its because with decreasing valve dia the flow velocity will increase, provided the inlet passage dia remains constant. So amount of fuel shall remain the same.
  • CE Designer
    I misinterpretted. I thought valve and passage were one and the same.
  • zaki_whiz03
    @zaki-whiz03-QzR6CP Jan 8, 2012
    mechkyI seriously doubt that. Its because with decreasing valve dia the flow velocity will increase, provided the inlet passage dia remains constant. So amount of fuel shall remain the same.
    If there is to be a change in the valve dia then the passage dia should be changed accordingly in order that the valve has a leak proof seat on it.
  • zaki_whiz03
    By reducing the inlet valve dia there should be a subsequent reduction in the passage dia. The flow velocity is increased during the suction stroke and turbulence is created in the combustion chamber which is essential for proper and complete combustion of the fuel-air mixture. If the exhaust valve dia is decreased then the resistance of the combustion products to flow out is increased as a result the stresses within the cylinder and especially on the piston is increased.
