i know that intensifier is used to increase the pressure intensity of liquid. I want to know about whether the temperature of water either change or not during operation. and if temperature changes than it changes on bases of which theory?0
Member • Aug 3, 2012
this i think so is based on the law of conservation of energy.
If the pressure intensity is increased, then it may be so at the expense of velocity. however 100% conversion does not take place and the losses may result in the heating of the fluid.Are you sure? This action cannot be undone. -
P(low)xV(low) = P(high)xV(high)
Temperature does not enter the picture.Are you sure? This action cannot be undone. -
Member • Aug 5, 2012
How do you explain this ?bioramaniP(low)xV(low) = P(high)xV(high)
The question appears to be about a hydarulic pressure intensiffication. In this a low pressure acts on a piston of large area. The movement of the piston pushes a smaller piston of smaller area in its cylinder. The pressure developed in the small cylinder will be the pressure in the big cylinder multiplied by the ratio of areas of the two pistons.Are you sure? This action cannot be undone. -
bioramaniThe question appears too be about a hydarulic pressure intensiffication. In this a low pressure acts on a piston of large area. The movement of the piston pushes a smaller piston of smaller area in its cyylinder. The pressure developed in the small cylinder will be the pressure in the big cylinder multiplied by the ratio of areas of the two pistons.
Oh alright , now i get it. I mistook the intensifier for a nozzle.Are you sure? This action cannot be undone. -
Member • Aug 12, 2012
thank for your good info. sir BioramaniAre you sure? This action cannot be undone.
