Not sure where else to put this so it will go here!😀 First off I have a question that I need help with, What would be the effect of subjecting a contained volume of gas to low frequency resonance? Gas= Not sure but lighter than air! Containment unit would be spherical! Frequency of resonance is yet to be determined! What I would like to know is will the contained gas become excited at some point and increase its lighter than air properties? This is for a project that I am thinking of getting into but time will tell.:sshhh: Just want to know that I am not going to level the neighborhood with a silly experiment. Dont think it would be wize to over-excite Hydrogen and such!lol Any help or ideas would be greatly appreciated!
Dear guest, you must be logged-in to participate on CrazyEngineers. We would love to have you as a
member of our community. Consider creating an
account or login.
Hm. What sort of resonance do you mean? What do you intend to use to make the gas "resonate"?
Note: there are several possibilities (mechanical stress or sound waves, magnetic or electric fields, heat). And what about temperature control/measurement?
Are you intending to investigate the pressure/volume relation for gases that resonate somehow, or what effect "resonance" has on density? A gas can respond to radio frequency energy, or to a magnetic field, or both. Then there's heat and sound. What have you considered is the best approach?
Using sound was the way I was going to go with this one! The sphere is set up as the centre of an audio speaker, oops that would mean it is vibration and then there is also the magnetic aspect of it as an assembly. So it could mean a combination of all???
The container will resonate with or without gas in it. You might want to determine as much as possible about the response of the container first. then a re-analysis with gas in the container (or with different gases).
Depending on how you measure the response of the "system" you should see a difference when the container is full or empty.
