Edge Trigger Code
qaisarpk1
@qaisarpk1-6Lfp0G โ€ข Oct 26, 2024
hi every one..
i want to make a up-down counter using 8051..
two switches are connected with UC.
one for up counting and one for down counting..
now the problem is that if i press one switch only at once it count correctly but if
switch is not released then it will not count only for once.....it count continuosly untill the switch is released.
i want to make it edge triger mean if a switch is pressed it will count when switch is released. if switch is hold for long time ,it must have to count only once...
i need c code or any algorithem ..
i m using keil c compiler..
thnx
    @harshad-ukH5ww • Jun 21, 2011
    qaisarpk1hi every one..
    thnx
    That is called KEY DEBOUNCE.
    what have you written? something like that? this is only if your switch is connected with Ground and you detect 0 at controller side.
    if(!SWITCH1)
    count++;
    Right?
    you can write
    while(!SWITCH) // in this case your execution waits untill you release the Key.
    count++
