ECIL GET-2012 exam for CSE
nareshkumar6539
@nareshkumar6539-BKuVbx โ€ข Oct 25, 2024
I gave exam for ECIL GET-2012 for CSE on June 10th 2012 here i am giving exam pattern and some of the questions they asked in the exam.
1)Exam consists of 50 questions,total questions belong to their respective branches
2)Every correct answer fetches 3 marks and every worng answer 1 mark deducted
3)Total quetions are multiple choice quetions
4)There are no aptitude questions.
5)Total marks 150.
here i am posting some questions what i remembered.
1)they gave some inorder traversal for a binary tree and asked for preorder of binary tree ?
2)No.of bytes in IP4 and IP6? 4 and 16 bytes
3)int main()
int i;
for(;scanf("%s",&i);printf("%d",i));
return 0;
output of the program? It will go to infinite loop
4)question regarding sub net mask
5)function calling itself directly or indirectly called ? Recursion
6)A list consists 100 numbers they used selection sort for sorting in first loop after completing 42 iterations how many numbers are there in exact positions?42
7)code coverge belongs to which testing?
8)Range of long double?
9) FFFF is a signed integer then its equivalent decimal value? -1
10)In cyclic redundency check CRC is?
a)remainder b)quetionet c)divident
11)c program output quetion related to call by reference?
12)what is isotope?equal number of protons
13)which of the followimg is not used in IPC(inter process communication) mechanism?
a)mailbox b)stack c)semaphore d)pipe
14)in which data structure we can insert elemnets in either ends but not in middle?
a)linked list b)stack c)queue d)dquee
15)Go-Back-N protocol is used for sending 10 data packets howmany acknowledge ments are expexts?
a)1 b)5 c)10 d)all of the above
16)to count the number of rows in a table which command is used? count()
17)with a structer pointer which operator is used to access the structer variable?
a) . b)* c)& d)->
18) c program output they give enum datatype
19)uml diagram
20)dbms which diagram are used to represent entity and relation ships
21)which of the foolwing is not functionalty of transport layer according to ISO/OSI layer?
a)segmentation b)routing c)service point addressing
Most of the questions they asked from c,c++ and DS out of 50 18 questions are came form these 3 only.
  • SWAGATA KUNDU
    @swagata-kundu-ZcaPc5 • Jun 19, 2012
    some qns of ecil 2012 are
    1why bit stuffing is used?
    2.https uses.
    3.what is aliasing in clp?
    4.rectifier uses
    5.8086 segmentation facility
    6.count() in sql
    7.code covering from software engineering-> white box testing
    8.one qn like peorder nd postorder
    9.:: why use in c++
    10.sign of destructure .
  • SWAGATA KUNDU
    can u tel me if there was any question about ackermann function in ecil 2012 exam
  • vinikatyal1
    @vinikatyal1-L9bGVV • Jun 19, 2012
    any idea what will be the cut off??
  • SWAGATA KUNDU
    dont know.but i have heard the cut off is very high ...about 70-75%.where the others have 50-55%
  • vinikatyal1
    Ohk that's very high
  • Sahithi Pallavi
    @sahithi-oJZaYj • Jun 29, 2012
    I took the exam last year. Most of the questions I got was from Computer Networks.
