@aliimran-Az5b1w • Jul 24, 2012
what exactly do you mean by earth resistance?
@fisfiseani-dRQYm1 • Jul 24, 2012
I mean to say earth pit resistance increases when there is increase in inductive load on the system (panel). What would be the reason behind this?
@ramani-VR4O43 • Jul 24, 2012
Why do you say inductive load? Is there no increase if the resistive load increases to the same extent? Most probably the earth it construction is such that the voltage drop across the earth connection itself changes. You may have to increase the conductor size. If possible measure the drop from panel to pithead as the load varies.
