  • reachrkata
    @reachrkata-FOcqhH Aug 18, 2010
    I dont see any particular difference except that in a single supply scenario, both the inputs need to be biased with 1/2 the supply voltage, what that is not needed in the dual supply case.
    πŸ˜’
    -Karthik
  • shreyasm89
    @shreyasm89-jGobVm Aug 25, 2010
    @Karthik- Why 1/2 the supply voltage? Any particular reason? From what we've been taught.....the symmetry of the inputs is required to eliminate the offset voltage. NO specific biasing voltage requirement is mentioned.Pls enlighten.πŸ˜€
  • swapnakumar
    @swapnakumar-lJkNkk Aug 25, 2010
    rakialiashow dual power supply is more useful over single power supply in differential amplifier in an op-amp? πŸ˜•
    dual supply is used for biasing purpose.
  • Arp
    Arp
    @arp-8yytsY Feb 6, 2011
    it is used to get the linearity in the system only using the semiconductor so as due to heat(which is always produced by any means and is a cause of non-linearity) we r having 2 power supplies so that +ve energy heat attracted by -ve supply and -ve energy heat extracted by +ve supply and thus we get what we require..
