Doubt in variable declaration and definition in C
piyushh
@piyushh-O70sb6 Oct 26, 2024
extern int a;
is it a declaration or a definition? the default value for extern type is zero so it can be treated as a "definition"...but why not for
static int a;
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Sep 23, 2011
    When you write extern int a; - it is a declaration not a definition. The extern keyword says that the variable is defined outside the function block.
    The following code will explain this:
    void func( );
    void main ( )
        func ( );
    void func ( )
        extern int var; //declaring a variable var which is outside the scope of this function (i.e. our global variable)
        printf ("%d", var);
    int var = 10; //Defining a global variable. This can be in another file also
    Note that we have declared (and defined) our global variable 'var' outside the func( ) block, and also way below the func ( ).
    Had we defined the global variable 'var' above the func() block, we wouldn't have to declare it using the extern keyword.
