doubt in java
neha1
@neha1-XOkqHl • Oct 25, 2024
hiiiiiiii
can any one tell me what condition we should give in if statement in order to execute both if and else statements??
for ex:
if( ???)
System.out.println("hello");
else
System.out.println("world");
it should print helloworld,,please fill ????
problem m facing is in ?? i provide int it doesnot accept...and ! condiiton is giving error if i use System.out.println() function,s return value...
pls solve it......
  • silverscorpion
    @silverscorpion-iJKtdQ May 14, 2010
    Well, I don't get your question.
    The point of using if is to do one job or the other based on some condition.
    If you want to do both the jobs, then you dont need to use if itself.
    Perhaps if you provide some sample code and say where you face problems, we can be able to help..
  • Manish Goyal
    @manish-r2Hoep May 14, 2010
    It is not possible
    at least for me don't know about james 😀
  • Morningdot Hablu
    @morningdot-6Xuj4M May 14, 2010
    ya goyal is right.
    but if it is a tricky question(we have to solve it by anyway).
    then i think that this is the method by which we have to do this.
    import java.io.*;
    class m
    public static void main(String arg[])
    boolean x;
    if(x=true)
    System.out.println("mohit ");
    x=false;
    continue;
    else
    System.out.println("cboy hack the world");
    but here what keyword is placed in the place of continue so that it will execute the if statement again.
  • optimystix
    @optimystix-4yMPKC May 14, 2010
    silverscorpionWell, I don't get your question.
    exactly!
    there's no point using an IF ELSE statement if both have to be typed. Even if it is a trick question, it is a foolish one 'cos one will never need an IF ELSE statement if both the things have to be worked out.
  • HImanshu_Sharma
    @himanshu-sharma-HOM7Hg May 15, 2010
    neha1hiiiiiiii
    for ex:
    if( ???)
    else
    pls solve it......
    public class demoif {
    public static void main(String[] args) throws Exception {
    if ( System.out.printf("Hello") == null ) {
    else {
    System.out.println("World");
    it is the perfect ans u can try
  • bharathkumarp
    @bharathkumarp-kwU5lr May 16, 2010
    Hey neha,if you want get the output as hello world, then try without else,then you definitely going to get the out put..But you can't get the both if and else part...
    other wise if you want to get those output fallow this code(using labels)...
    int a=1;
    l1:if(a==1)
    a=0;
    else
    goto l1;
    this is work in c and c++,, But i'm not sure in java.. Just try...
  • silverscorpion
    @silverscorpion-iJKtdQ May 16, 2010
    bharathkumarpHey neha,if you want get the output as hello world, then try without else,then you definitely going to get the out put..But you can't get the both if and else part...
    int a=1;
    l1:if(a==1)
    a=0;
    else
    goto l1;
    Hey, this is an infinite loop man.. It'll go on printing
    helloworldworldworldworld....
  • AGRU
    @agru-00oqkR May 21, 2010
    yup , silverscorpion is right it goes fr infinite loop.
    i believe that we use " if else "only in case we want to solve cases of either or still if u solely aim only to print " hello world "
    then try like
    import java.io.*;
    class trial
    boolean x;
    int c=0;
    while (c<2)
    if(x=true)
    System.out.println("hello" );
    x=false;
    else
    System.out.println("world" );
    c=c + 1;
    but its like getting something purposefully.
    help me if i m wrong.
  • bharathkumarp
    @bharathkumarp-kwU5lr May 22, 2010
    hi #-Link-Snipped-#, ya i am wrong.. But i can modify that code as fallow, If there is mistake please inform me and let me know how can write....
    int a=1,b=0;
    l1:if(a==1)
    a=0;
    else
    if(b==0)
    b=1;
    goto l1;
