Doubt in java programming-2.
hello friends,
I write a program to copy a text file in java.
But i didn't get the text in serial way.
Check out this
import java.io.*;
public class r
public static void main(String args[])throws IOException
FileInputStream f=new FileInputStream("monu.txt");
InputStreamReader isr=new InputStreamReader(f);
BufferedReader b=new BufferedReader(isr);
char s;
int t;
FileOutputStream ff=new FileOutputStream("kumar.txt");
OutputStreamWriter osr=new OutputStreamWriter(ff);
BufferedWriter br=new BufferedWriter(osr);
do
s=(char) b.read();
if((t=b.read())!=1)
br.write(s);
while((t=b.read())!=-1);
br.close();
any help will be appreciated.
  • Manish Goyal
    @manish-r2Hoep Aug 28, 2010
    Check this program .i have tried this by using both do while and while loop
    using while loop output is perfect but using do while there is one extra character added
    since in do while which is exit controlled loop first statement is executed then condition is checked therefore an extra character is added but in case of while loop which is entry controlled loop the ouptut is correct
    import java.io.*;
    public class T
    int t;
    /*while((t=b.read())!=-1)
    br.write((char)t);
    do
    t=b.read();
    br.write((char)t);
    while(t!=-1);
    br.close();
    b.close();
  • Morningdot Hablu
    @morningdot-6Xuj4M Aug 28, 2010
    Thanks goyal.
    But it work fine in window but not in ubuntu.
    It will show a character encoding error when i want to open it with gpedit.
