how to test which is primary and which is secondary coil in transformer.in both the primary and secondary side there are only two wires.please help me...it is urgent0
Member • Aug 25, 2012
It is you who will decide which will be primary and which will be secondary coil.
If you want stepdown transformer, turns in primary are more than secondary and if you want stepup then vice versa.Are you sure? This action cannot be undone. -
<a href="https://en.wikipedia.org/wiki/Transformer" target="_blank" rel="nofollow noopener noreferrer">Transformer - Wikipedia</a>
check this out all about transformersAre you sure? This action cannot be undone. -
haha, theoretical world mate..😁Troll_So_HardIt is you who will decide which will be primary and which will be secondary coil.
In actual transformer, you cannot distinguish between primary & secondary winding just by looking at it.
Here are 2 possible methods which I can think of now.
Try checking the impedance of the windings. The high impedance one will certainly be primary & lower impedance one will be secondary.
Other method, a little risky one, would be to apply input to one of the windings & check the output at the other. Depending on the type of transformer, you'll be able to determine the windings from the output obtained at the other terminal.Are you sure? This action cannot be undone. -
[Prototype]Other method, a little risky one, would be to apply input to one of the windings & check the output at the other. Depending on the type of transformer, you'll be able to determine the windings from the output obtained at the other terminal.
this can be made harm free by applying little higher voltage and less current
the current has to be reduced if higher voltage is used for the power rating of any transformer is constant and if this power rating is exceeded transformer will blow up
try it and if voltage op is lesser then that is the primary side of step down transformer and vice versaAre you sure? This action cannot be undone. -
thank you allAre you sure? This action cannot be undone. -
primary wdg always connect with input source and secondary connect with loadAre you sure? This action cannot be undone. -
but the qn here is how to differentiate between themrajk. sharmaprimary wdg always connect with input source and secondary connect with loadAre you sure? This action cannot be undone.
