Does BOP rule for 2015 pattern is still there in pune university
In Se i have failed in 2 subjects and in 1 subject i got after revaluation total 39 marks out of 40 in 1 attempt. And in 2 attempt i got total 35 marks.   then I’m eligible for BOP rule or not.
    @thebigk May 25, 2018
    AFAIK, The BOP rule works like this -
    You can get up to 10 grace marks but ONLY IF you've cleared all the other subjects without any grace marks. It also requires that you have not used the BoP advantage earlier (it can be used only once).
    My best guess is that the BOP won't be applicable in your case.
  • Mangesh Shelar
    @mangesh-dAGJ0G May 25, 2018
    And what if I passed in all other subjects then ???
    #-Link-Snipped-#‍ - It should be applicable then. You'll have to contact the University authorities anyway. I'm not sure if they work it out on their own or the candidates have to go through a process.
  • Mangesh Shelar
    And if i got failed in 1 subject and i appear for that subject again but i failed in that subject again but after revaluation my that subject is back by 1 mark only  which i attempt 1 time . but  my revaluation result is late.   Soo then which marks will be calculated and can i get 1 mark gracw there
