Do you know dry ice?
abmish
@abmish-GGafrg โ€ข Oct 26, 2024
Hello friends,
Here i am explaining DRY ICE.Solid carbon dioxide is known as dry ice.It is soft,white snow like substance and looks like ice.However,it does not wet a piece of cloth or paper because it sublimes without melting.Solid carbon dioxide is used as refrigerant under the commercial name drikold.
thank you.
AB MISH
  • funmonster
    @funmonster-x0ZBEH • Jan 21, 2010
    abmishHello friends,
    thank you.
    AB MISH
    when it is dipped in water produces fumes... check it out...
  • sumitkumarjha
    @sumitkumarjha-e1q62t • Mar 11, 2010
    dry ice is solid CO2.it is widely used in refrigerating materials while it is being transported.It's main advantage is that it can be casted/sliced into different shapes and gives a refrigerating condition of about -78`C.
  • callyD
    @callyd-6BKFb3 • Mar 14, 2010
    It's called dry ice because it doesn't melt into a wet liquid. And dry ice is used to create smoke and fog special effects
  • Gurjap
    @gurjap-blPmg9 • Mar 23, 2010
    um, what be this, a show-off thread?
  • imaimen
    @imaimen-yyO066 • Mar 24, 2010
    Thank you for the information, hope this can improve my knowledge ๐Ÿ˜€
  • MaRo
    @maro-Ce3knx • Mar 25, 2010
    Hot ice? difference?
  • martincrow
    @martincrow-0TCTDa • Jun 5, 2011
    Dry ice is used as the cooling agent when there is no mechanical cooling is available, it is useful for the preservation of the frozen foods, and it is the solid form of the carbon dioxide. Dry ice can also be used for the prevention of the insects from the stored grains, in chemical industries it is used to it is used in the chemical reactions to evaporate the organic solvents.
  • vijaya12
    @vijaya12-pXhbA7 • Aug 7, 2011
    Hi,
    Hello friends,Here i am explaining DRY ICE .Dry ice which is also called as cardice or card ice. It is the solid form of carbon dioxide. Its advantages include lower temperature than that of water ice and not leaving any residue (other than incidental frost from moisture in the atmosphere). It is useful for preserving frozen foods, ice cream, etc., where mechanical cooling is unavailable. The low temperature makes it useful for inserting or removing engine cylinder liners that are held in place by friction. It may also be used to generate carbon dioxide gas to displace oxygen-bearing atmosphere and to carbonate liquids. If u want to find dry ice manufacturers <link removed>
  • Godfrey
    @godfrey-ixuYws • Sep 20, 2011
    Dry ice which is also called as card ice or card ice. It is the solid form of carbon dioxide. Its advantages include lower temperature than that of water ice and not leaving any residue (other than incidental frost from moisture in the atmosphere). It is useful for preserving frozen foods, ice cream, etc., where mechanical cooling is unavailable. The low temperature makes it useful for inserting or removing engine cylinder liners that are held in place by friction. It may also be used to generate carbon dioxide gas to displace oxygen-bearing atmosphere and to carbonate liquids.
