DIY steel silver alloy
Alloyau
@alloyau-uY7LwS Oct 26, 2024
Hello everyone,
I want to alloys steel with silver or gold or platina. How can I do this?
I read in a book that by making a battery using a silver electrode and a steel electrode the result would be a silver steel molecule wich would settle at the bottom of the battery as sludge after each time the battery is recharged. Is this right? What happens in a steel silver battery if it is recharged, is there a steel silver molecule as a result?
If I wanted to melt the two metals together using a 7kw induction heater how would I go about to blend these two metals? Would I use a flux? what crucible would be resistant to the alloy and flux? How do I make them homogenous? How do I go about the whole procedure from start to finnish?
Mr Alloyau
    @ramani-VR4O43 Oct 18, 2011
    There is no such thing as a silver steel molecule. Steel is not an element.
    Are you considering an iron - silver battery? If so, the two metals have to be kept separate, silver as anode and iron as cathode.
    There is a very real possibility of the world being out of silver as early as 2020 AD. May be better to avoid any development using silver.
    <a href="https://www.freepatentsonline.com/5429894.html" target="_blank" rel="nofollow noopener noreferrer">Silver-iron battery - Westinghouse Elec. Corp.</a>
  • Alloyau
    @alloyau-uY7LwS Oct 31, 2011
    Thank you for answering,
    Yes,
    I am aware that alloys are not molecules. However I want to alloy steel/iron and silver in a homogenous form. When I blend them it is like blending water and oil, they seperate. How do I go about making a uniform steel-silver alloy? Or steel-gold alloy?
    I can use borax from what I´ve understood to make the mixture homogenous right? Can I do this with out using borax?
    The equiment I have available is a 7kw induction heater and Zircon-Mullite crucibles, 15mm in diameter and 20mm tall. How do I do this? Do I melt the metals seperately or together? How do I find out the ratio of each metal in weight to make them as uniform as possible? etc. for every Silver atom how many iron/steel atoms?
    Does anyone know what is exactly happening inside a silver-iron battery? If I open such a battery there is a paste on the bottom that has gathered from discharging and charging the battery over time. WHAT is that paste? Is it not a silver-iron alloy?
    If I wanted to make my own silver-iron battery, is this procedure correct?
    1. 4 sheets of Silver for the positive side,
    2. 5 sheets of Iron for the negative using lead terminals for each side.
    3. Assembly as standard battery form.
    4. Electrolyte from distilled water and Sodium Cyanide, compounded to a density to provide a circuit of conductivity of two and a half volts resistance.
    I found this in a book, why does the author use the word compund molecules?
    "When uniting the Silver and Iron into compound molecules, each molecule is no doubt composed
    of one silver atom and two or more Iron atoms."
    Anyone?
    @ramani-VR4O43 Oct 31, 2011
    If this is your reference I am afraid you may be in for a disappointment. I do not think that the electrochemistry part is correct.
  • Tammy1949
    @tammy1949-wTE1I0 Nov 6, 2011
  • Alloyau
    @alloyau-uY7LwS Nov 12, 2011
    Hello,
    Thank you for the answer, but it would help more if you could precisely point out where exactly the pdf. file electrinium is wrong? Please use facts only, opinions are for no use. However I am more interested in answers to my previous questions, I am less interested wether it works or not.
    Questions:
    1. Is it possible to make single silver-iron molecule/alloy?
    2. How do I go about it? step by step blending silver and iron into a uniform homogenous mixture. What crucibles to use? borax or no borax? etc.
    I am not interested in oinions. I wellcome all facts and good ideas. Leave out your opions for the sake of space, time and energy.
    @ramani-VR4O43 Nov 12, 2011
    AlloyauQuestions:
    Since opinions are unwelcome , my answer to both questions is : I do not know.
  • Alloyau
    Great, now we are getting somewhere. 😀
    If you feel like embarking on an exciting journey you are wellcome to help. lets us first melt silver and steel into a polar alloy. If you read the pdf. a few times it will all come together for you. Personally I see no false reasoning in it.
