Dish antenna positioning system using telephone
g5k123
@g5k123-zOyLVM โ€ข Oct 26, 2024
hi there, can u please provide me some details regarding "Dish antenna positioning system using telephone".....๐Ÿ˜€
    @thebigk • Mar 15, 2009
    What details do you want? It helps to ask specific questions!
  • g5k123
    g5k123 OP
    @g5k123-zOyLVM • Mar 16, 2009
    for vertical and horizontal positioning should i use 2 stepper motors or 1 is enough with some gear stuff?
  • g5k123
    g5k123 OP
    @g5k123-zOyLVM • Apr 23, 2009
    hi can u send me the circuit diagram of all the circuits used in this project ๐Ÿ˜’
  • Ashraf HZ
    @Ash • Apr 30, 2009
    No, 2 separate motors is better. You'd want independent positioning ๐Ÿ˜€
    Regarding the circuit diagram, you should attempt it yourself and then come back here if you get stuck. Firstly, list out all the requirements you need for the project.. for example, in what way are you you using the telephone to control the positioning? Are you using each number key via PSTN to remotely control the antenna far away?
