@gohm-F3UUpP • May 13, 2009
Think of ABS as a braking accessory that works with the disc or drum braking system. ABS uses sensors to monitor the wheels. Once wheel lock is acheived, the ABS system activates and begins to rapidly pulse the brake system, thus eliminating wheel lock and allowing control under braking conditions.
Vijay Balaji OP
@vijay-balaji-lZxMdE • May 13, 2009
is there a mechanical abs
@gohm-F3UUpP • May 14, 2009
Yes, before ABS was electronic, there were mechaincal means
Vijay Balaji OP
@vijay-balaji-lZxMdE • May 14, 2009
๐I cannot find anything about mechanical abs in the internet...can u tell me the website where i can find mechanical abs..I'm planning to do a project work on it..
@gohm-F3UUpP • May 15, 2009
You are probably going to have to invest more time then a simple internet search. I don't believe anyone uses mechanical abs anymore so you will need to consult some auto design books, auto history books, library, etc. the info is out there.
Also, i just noticed wikipedia has a small sound bite on them, maybe you can dig a bit deeper in your internet search? -
Vijay Balaji OP
@vijay-balaji-lZxMdE • May 15, 2009
i"m planning to do a project based on mechanical abs...till now i havent heard about mechanical abs
Vijay Balaji OP
CAN U suggest any new innovative ideas that i could work on..
@gohm-F3UUpP • May 16, 2009
Automated emergency braking systems are being developed and put into production. How about that?
Vijay Balaji OP
@vijay-balaji-lZxMdE • May 16, 2009
thank u..that was usefull info
@cuga-tVWFpu • Jun 21, 2009
@shrinkdworld-WWdBBc • Jun 21, 2009
If any one have information about abs please post it in this thread..
@veena912-XZxaY9 • Jun 25, 2009
4 wheel disc brakes simply mean that they are disc on all four wheels as opposed to drum brakes in the back like usuall. Disc are better, easier to fix but you wouldn't be able to tell the difference anyway. Now ABS means Anti-locking Brake System. Now this means that when you slam on the brake pedal to stop real fast that your wheels will not lock up and you will not slide. Making you stop faster and with less effort. Its great in the rain or ice it helps SO much. in my opinion you should ALWAYS buy a car with ABS its a huge difference, and much much safer.. Its worth it, expecialy if you are buying a new car. ...good luck and if u still dont understand ,,write me.
4me rather than trying ABS just go EWB ( ELECTRONIC WEDGE BRAKE SYSTEM)
which are far more superior than ABS because the braking is done by the wedges but both have one thing in common both are actuated by sensors, though you have cars with ABS these EWB are still in prototype stages .
