@ramani-VR4O43 • Jun 17, 2012
Thick and thin:
@jaspal-rautela-yw5rJz • Jun 17, 2012
i am asking about cylinder................
The question must have enough info for a meaningful answer. Otherwise the only difference is that one is thick and the other thin. Are they hollow cylinders? Do they contain pressure? What is the intended purpose?
@thebigk • Jun 17, 2012
jaspal rautelawhat is difference between thick and thin cylinder?
The question needs to be more informative. Else, the answer would be same as post #2 above. Are you, in any way, asking about Comparison of stress systems between thin and thick cylinder? 😨
PS: We're no mind readers, so you will have to explain your question in detail. -
@mechky-jbqpJD • Jun 18, 2012
If the wall thickness of the cylinder is less than 1/10 of the diameter of the cylinder, then it is called a thin cylinder. If the wall thickness of the cylinder is greater than 1/10 of the diameter of the cylinder, then it is called a thick cylinder.
