Difference between line and phase
satty lavanya
satty lavanya
@satty-lavanya-4IoUgk Oct 27, 2024
can any one tell me the difference between line and phase...
    @thebigk Dec 20, 2012
    satty lavanya
    It's easy. Would you like to make an attempt at it on your own? Tell us what's your understanding of these terms (apart from the dictionary definitions, of course). That'd be a better approach to learning. What say?
  • satty lavanya
    satty lavanya
    @satty-lavanya-4IoUgk Dec 20, 2012
    The_Big_K
    k..i wil........ i think line is the electrical current between line to line.here.there is no use of neutral current.but.in phase........is is the electrical current between.line and neutral......
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Dec 21, 2012
    They are voltages and not current references my friend.
  • satty lavanya
    satty lavanya
    @satty-lavanya-4IoUgk Dec 22, 2012
    Conqueror
    Conqueror
    no in reference to curents wil be there na.....
    Abhishek Rawal
    @abhishek-fg9tRh Dec 22, 2012
    There is line current and there is phase current. There is line Voltage and phase voltage too.
    So, what you are looking for, in terms of current or voltage??
    These terms are clearly mentioned in almost all reference books. I suggest you to go through it.
  • pinank
    pinank
    @pinank-6TUo5O Dec 22, 2012
    in electrical systems there are multi phase circuits likely three phase or single phase circuits.. so difference in potential between any two phases is th line voltage...where as difference in potential between a single phase and ground is called the phase voltage.... assume a star connected load then the potential difference between r and common neutral is the phase voltage but in delta connected load the difference between ry or rb is called the line voltage...
