Difference between half controlled and full controlled bridge rectifier
Rajasekhar Ramireddy
@rajasekhar-G2jkv1 โ€ข Oct 26, 2024
what is the difference between half controlled and full controlled bridge rectifier.when we can control the voltage with half controlled bridge rectifier, why going for full.what is the difference that it makes... are there any different applications for both the rectifiers....
    @ramani-VR4O43 Nov 20, 2013
    rajtheking46what is the difference between half controlled and full controlled bridge rectifier.when we can control the voltage with half controlled bridge rectifier, why going for full.what is the difference that it makes... are there any different applications for both the rectifiers....
    Are you by chance referring to half wave and full wave bridge rectifiers?
  • ABCD ABCD
    @abcd-2NEyMb Nov 20, 2013
    Controlled HW rectifiers and FW rectifiers are both used in power control applications. Consider and water heating application to understand.
  • Rajasekhar Ramireddy
    @rajasekhar-G2jkv1 Nov 20, 2013
    mreccentricControlled HW rectifiers and FW rectifiers are both used in power control applications. Consider and water heating application to understand.
    A.V.RamaniAre you by chance referring to half wave and full wave bridge rectifiers?
    no sir...i am not asking about half wave and full wave rectifier....i am asking about phase controlled rectifiers which involves thyristors and diodes for rectification and where we can control the output dc voltage by varying the firing angle given to the thyristor........
    @ramani-VR4O43 Nov 21, 2013
    rajtheking46.i am asking about phase controlled rectifiers which involves thyristors and diodes for rectification and where we can control the output dc voltage by varying the firing angle given to the thyristor........
    I have used a large number of such phase angle controlled power supplies for low voltage high amperage (up to 10000A) electrochemical processes. The fractured wave forms do not matter in these processes and may even be better.
