  • Difference between current & electricity?
    ganesh p
    ganesh p
    @ganesh-p-EPjflj
    Updated: Oct 27, 2024
    Views: 1.8K
    WHAT IS THE DIFFERENCE BETWEEN CURRENT AND ELECTRICITY?
    AdministratorSep 18, 2012
    First of all, please provide attention to the titles of your post. 'basics' makes no sense and I hope you will agree that the title I've updated makes more sense. Also, fix the CAPS LOCK key on your keyboard, it seems to be broken.
    Current is a general characteristic of electricity, like voltage and resistance. It's a name given to the flow of electrons (charge) through a medium. Electricity is a generic name that's used for the common flow of energy to power all the electric stuff.
    Current in general refers to any flow. Thermal currents, currents in a river and also electric currents.
    Electricity deals with charges on ions, electrons and their movement.
  • Jeffrey Arulraj
    MemberSep 19, 2012
    Electricity is flow of power in the electrons state
    Current in general is flow of power in any form
  • Tarun Goel
    MemberOct 5, 2012
    bioramani
    if electricity it is flow of electrons then what is thundering?
    AdministratorOct 5, 2012
    tarun goel
    It's still the electrons.
  • Tarun Goel
    MemberOct 5, 2012
    The_Big_K
    Electrons in free air?
  • Jeffrey Arulraj
    MemberOct 5, 2012
    tarun goel
    yes Why are there no atoms in air ??
    If atoms are present electrons are present
    tarun goel
    Well, they need not be free electrons but charged water particles (droplets) and air molecules. When the static charge exceeds the breakdown voltage between the source (clouds) and sink ground, another cloud or other there is a discharge. The violent discharge causes the air in the path to expand and rush away creating a vacuum. After the flash ends the air rushes back with a clap, which we call thunder.
  • arunchary
    MemberOct 6, 2012
    thunder is a heavy and weighted electronic composition ,when it fall on the ground simply it creates drill like structure...its may be in many time bigger then magawatt power.................
    arunchary
    Thunder is just the sound. It does not do any damage except to ear drums if too near.
    Lightning can damage. It is a static discharge of mega proportions. It need not always strike the ground. More often it is between clouds carrying opposite charges. Lightning strikes the highest point on the ground which is tops of buildings and trees and such. Rarely it hits the ground. It does strike the ground if there are conducting minerals or metal ore.
  • Jeffrey Arulraj
    MemberOct 6, 2012
    Hello here thunder causes near vaccum state due to very high amount of charge passage in less time period this causes all the disturbances
    Read bioSir's post that explains the effect more clearly
  • Henri
    MemberOct 9, 2012
    although the two terms might seem almost similar,they are not.Whereas electricity refers to the flow of energy in form of electrons,current refers to the flow of energy in any form from say thermal to electric.So,yeah...in as much as the defination of electricity can be substituted for current,,there is a slight difference
  • Henri
    MemberOct 9, 2012
    thundering refers to the sound produced when there is neutralisation of positive and negative ions within the atmosphere...so thunder can never be electrons whatsoever
  • Henri
    MemberOct 9, 2012
    bioramani
    thats is true
  • Henri
    MemberOct 9, 2012
    arunchary
    thunder is simply a sound..lightining maybe..but that being weighted in electronic proportions,,,that is absurd
  • grsalvi
    MemberOct 10, 2012
    CEans the flow of charged ions can be also responsible for electric current , right ?
    In case of lightning there are free electrons but also a majority of charged ions of air ,water ,etc.
  • Jeffrey Arulraj
    MemberOct 10, 2012
    But the current due to them is always less as the mobility is inhibited cos of their size
  • grsalvi
    MemberOct 10, 2012
    Charged ions charges similar to free electrons ( After all the birth of free electron and charged ion is a same incident ).
    Now mobility ,off course its less in solids but what if its in gases(air in lightning ) and liquids (electrolytic process in batteries ) ?
  • Jeffrey Arulraj
    MemberOct 11, 2012
    Not real significance due to neighbouring atoms Can contribute very less current only
  • subaBE
    MemberJan 23, 2013
    when this static voltage may increasing for causing thunder?it have any specific limits?
  • Jeffrey Arulraj
    MemberJan 25, 2013
    subaBE
    The static voltage must exceed the ionising voltage of air through the entire distance it has to travel from the sky to the surface of the earth Lightning occurs
    It does not have a fixed value. It must be over 1kV
  • Yournished
    MemberFeb 9, 2013
    Electricity is a very general term used do describe current and voltage, the fields they produce, and other effects like induction, charge, capacitance, resistance...etc.Current is a term to describe the physical movement of electrons through a material.Voltage is energy. It is the force or charge applied to incite the movement of the electrons.
  • Ayush Labh
    MemberNov 2, 2014
    What's the diff. Between current electricity and electric current ?
    AdministratorNov 2, 2014
    Ayush Labh
    Have you tried referring to basic physics books? If not, try searching the Internet and let us know what you discover.
    Ayush Labh
    Anyway, you're not the only one with this question. This question has been asked before : <a href="https://www.crazyengineers.com/threads/difference-between-current-electricity.59410">Difference between current & electricity?</a> . I will merge the discussions later.
