@thebigk • Mar 2, 2009
Rambo - if you add more of those 'Technical Staffing' links, you'll be banned.
@santoshsexysahu-4irrRr • Mar 8, 2009
yaa it is a great que.c++ is a language in oops family..which we use (class)๐.it is better then c.but still u will b using 'c' concept..
if u can write at where u r confusing..then i'll try to clarify ur doubt
@komputergeek-Yf5hJ4 • Mar 8, 2009
C++ can use all the features of C.In addition to that,it uses features of object oriented programming (i.e Classes,Inheritance,Abstraction,Encapsulation,Polymorphism etc).This brings more simplicity in implementation.
@rama-krish627-LuiiO6 • Mar 8, 2009
Hi Rambo. Good question. C++ is basically C language with Object Oriented features. It supports Object Oriented features like Inheritance, Polymorphism, Overloading and so many concepts that make the programming easy to us in out daily life.
@ashutosh-shukla-ed4Ei4 • Mar 9, 2009
Hey people stop getting confused,
See as the name suggests C++ means C with the extensions.
C ++ is C plus the OOPS concept.
C++ takes its syntax somewhat from the C
The major difference is same as the difference between procedural and object oriented language You can find this in any book that deals with programming languages
Still
๐
๐
๐
