can i know what is the main difference between ac and dc????0
Member • Sep 13, 2012
AC current that is "alternating current" as the name itself says "alternating" which means it has both +ve half cycle and -ve half cycle of current. hence we all it alternating currentjyothirmaijocan i know what is the main difference between ac and dc????
whereas, DC current only consist of +ve half cycle of current!Are you sure? This action cannot be undone. -
To add more AC current are sine wave wereas DC current is a straight line,AC Current has 3-Phases while DC current do not have any phasesVishal0203AC current that is "alternating current" as the name itself says "alternating" which means it has both +ve half cycle and -ve half cycle of current. hence we all it alternating current
ac current means alternating current which has the sinusodial current and dc current that is direct current which has the constant current supply....Are you sure? This action cannot be undone. -
i think #-Link-Snipped-# said the same thing abovesatty lavanyaac current means alternating current which has the sinusodial current and dc current that is direct current which has the constant current supply....Are you sure? This action cannot be undone. -
Administrator • Sep 13, 2012
In order to understand the basic difference between AC and DC currents, one must go into the roots of how electricity is produced. Also, as noted earlier, it's important to visualise the AC current (in its graphical form) to have clear thoughts on how it differs from DC current.
I'd like to leave you with another question to explore: Why is AC a preferred type for longer transmissions? ( this could very well be your viva question )Are you sure? This action cannot be undone. -
The transformers steps up increasing its voltage for longer distance transmission .... while the electric box you find near your lane/society/building consists of step down kit to decrease voltage for local area/residential area transmission.
HVDC can be used for power supply to longer distance but it is not preferred for local area. why ? maybe because in DC supply once you get short its impossible to come out alive .... while in AC due to its property of di/dt it is more convenient.
If any other reason .... elaborate please.Are you sure? This action cannot be undone. -
Could I post a fundamental question on this. How would we classify a current output from a sensor like a photodiode in varying light intensity.Are you sure? This action cannot be undone. -
Member • Sep 14, 2012
AC current has an altering +ve and -ve peak voltage in it the current varies with time ie AC current is a function of time
where as the DC current is not so it has a constant value at any instant of time . the two possible states available in DC current is ON state end OFF stateAre you sure? This action cannot be undone. -
thank you every one for ur valuble answers.................Are you sure? This action cannot be undone. -
here is the document you can get better understand...Are you sure? This action cannot be undone. -
Member • Sep 15, 2012
ya.i know.but..i thought.... while giving the answer is what in my view.i should post the answer....if another person said the same thong or notVishal0203i think #-Link-Snipped-# said the same thing aboveAre you sure? This action cannot be undone. -
Avinash SCould I post a fundamental question on this. How would we classify a current output from a sensor like a photodiode in varying light intensity.
it is not AC it is merely a DC having some AC ripples and
any ways the curve get is an exponentially decreasing one and not a sinusoidal one in the case of photo diode and stuff like thatAre you sure? This action cannot be undone. -
Member • Sep 16, 2012
multivibrator works on AC or DC ( corect my answer .... as u said DC has only ON OFF conditions........ MULTIVIBRATOR should be worked in DC ???? )jeffrey samuelAC current has an altering +ve and -ve peak voltage in it the current varies with time ie AC current is a function of time
If we concern about wireless Tranmission.. over long-distance ;only a.c. can be used.. d.c. signal can't generate E.M. waves via antenna.(we can't get varying ele. as well as magn. field). so there shouldn't doubt on long dist. commn.Are you sure? This action cannot be undone. -
it is not AC signal used for transmissionNishant PatelIf we concern about wireless Tranmission.. over long-distance ;only a.c. can be used.. d.c. signal can't generate E.M. waves via antenna.(we can't get varying ele. as well as magn. field). so there shouldn't doubt on long dist. commn.
we use analog signal here instead of digital signal
they are different AC DC ANALOG AND DIGITALAre you sure? This action cannot be undone. -
can you tell what is a multi vibrator that itself tells the answer to your postnaveeemultivibrator works on AC or DC ( corect my answer .... as u said DC has only ON OFF conditions........ MULTIVIBRATOR should be worked in DC ???? )Are you sure? This action cannot be undone. -
Member • Sep 17, 2012
a device that produce clock signals for digital circuits 😀jeffrey samuelcan you tell what is a multi vibrator that itself tells the answer to your postAre you sure? This action cannot be undone. -
AC current reverses its direction while flowing in a circuit..whereas DC current It flows in one direction in the circuit....
AC current is the current of magnitude varying with time..in DC the current has a constant magnitude!
here the ip is DC supply but the op is digital and not AC
kindly don't confuse AC and digital signal guysAre you sure? This action cannot be undone. -
Member • Sep 18, 2012
I feel everyone should hit wikepedia to understand electricity,we are wayward from the actual question and moving more towards electronics and digital signal.Are you sure? This action cannot be undone. -
there is an unnecessary confusion here about ANALOG DIGITAL AC AND DC signal
some are confusing current with signalAre you sure? This action cannot be undone. -
AC-average value=0
DC-average value=finiteAre you sure? This action cannot be undone. -
Member • Sep 21, 2012
ya..its exactly an analog signal..not an AC.Are you sure? This action cannot be undone.
