@jeffrey-xA7lUP • Jul 30, 2013
Hey mate nice question
But I am in noway aware of the ratings you are looking for
Is your supply to be a stepup supply or a stepdown supply Do elaborate on the Voltage specs of the design -
@aady-007-VTxfoJ • Jul 31, 2013
step down
@jeffrey-xA7lUP • Aug 1, 2013
Voltage ratings mate Step down what
415 to ??๐ Or is it 230 to ??
Do update here we are sure to aid you more๐ -
@aalandkar-R9Nf1k • Aug 8, 2013
Dude use lm317 for the variable power supply if u want a limited range. Else go for series pass supply using transistors.
@jeffrey-xA7lUP • Aug 8, 2013
a.alandkarDude use lm317 for the variable power supply if u want a limited range. Else go for series pass supply using transistors.
LM317 is for upto 21 or a max of 23 Volts at very low current He has not posted any details regarding that So this question has too many possible answer
@pinank-6TUo5O • Aug 22, 2013
U can step down the input power by using a transformer and then use a full wave rectifier, filter and voltage regulator (lm317) to set the constant voltage level...then use a pot to get the variable voltage...
@halil-alper-onay-zwLtYk • Aug 29, 2013
You can find all your answers from the book ' Power Electronics-Mohan'.
