Designing an automobile from scratch
zaveri
@zaveri-5TD6Sk Oct 25, 2024
While doing this, which would be the first subsystem, that would be designed ?
well everyone may say that it is the chassis frame.
but the real answer is the suspension system.
Can anyone justify this ?
  • zaveri
    @zaveri-5TD6Sk Oct 22, 2012
    Maybe, when the suspension is designed first, then a mathematical model involving the spring-mass-damper system is created and evaluated.
    by doing this, the values of spring stiffness and damping co-efficient is obtained.
    what are your takes ?
  • white_hat
    @white-hat-RTFca6 Oct 22, 2012
    How do you design the suspension system without knowing the total weight of the chassis?
  • white_hat
    I think we should start from inside out. First start with the number of seats and build
    a car around it.
  • zaveri
    obviously the total weight of the chassis will never be known, but an assumption can be made such as:
    the (chassis weight + the weight of all subsystems + the total weight of all the passengers + the weight of payload ) * 1.2 times this weight as factor safety.
    this value can always be changed as we move ahead with our designing process, since the entire process is an iterative one.
  • white_hat
    @white-hat-RTFca6 Oct 23, 2012
    What is the advantage in designing suspension system at first.Does it make any difference, does it make the whole designing process easy?
    Am not trying to argue with you , just for the sake of knowing it.
  • zaveri
    @zaveri-5TD6Sk Oct 23, 2012
    to be honest, the same thing confuses me.
    according to me, the first part which should be designed is the chassis frame, but then some guys in my class who had just attended a workshop, told me that the designing should from start from the suspension. but he couldn't justify it either. so i wondered if any experienced CEan can throw more light on this.
