  • Design Mix of Pump Concrete
    sagar1432
    Member
    Updated: Oct 20, 2024
    Hi, which is the reference code for Design Mix of Pump Concrete.
  • gohm
    MemberMar 20, 2009
    Everyone will have a slightly different concrete recipe. This in turn will be altered by time of year, weather, application & mix requirements. This site will give some further info:
  • emendy
    MemberMay 6, 2010
    the basic requirements of the concrete mix design for the pumped concrete are:
    1) the slump should be atleast 100 mm at the placing point.
    2) The use of admixtures to be made to make a suitable slump and not compromise on W/C ratio
    3) the coarse aggregate should preferably be 20 mm down strictly.
    4) the coarse aggregate should preferably be processed through Vertical shaft impactor.
    5) use of fly ash be made as cement replacement if OPC is used.
    experts can add to the inputs.
    regards
    Emendy
  • maria flor
    MemberApr 23, 2011
    What is a pump concrete???😉
  • engr.kris
    MemberOct 23, 2011
    its a truck mounted pump for concrete flor, its purpose is to convey fresh concrete to higher elevation.
