DESIGN AND STUDY OF WIND-SOLAR HYBRID SYSTEM FOR DOMESTIC APPLICATION IN REMOTE VILLAGES OF INDIA
Project Abstract / Summary : Increasing levels of modernization in different countries worldwide has lead to an exponential growth in national energy demand. India with its huge population base had a total grid connected electric power close to 285 GW during 2015 with annual generation of 1106 TWh accounting to a per-capita energy consumption of 746kWh. The Government of India under its ambitious plan “Power for all” envisages 24x7-power supply for the entire domestic and Industrial loads by the year 2022. This power sector initiative also promises the generation through green path by targeting reduction in carbon-footprint. The plan has sanctioned funds for production of 190 GW power based on go-green initiative of United Nations Organization and a step forward to create a better environment for future generations. The proposed work aims at design of wind-solar hybrid system for light load decentralized applications. The computational tools were used to model and analyze wind turbine (WT) blade structure for low power applications to suit decentralized power generation based on renewable energy. The comparative studies of test aerofoil with standard NACA0018 aerofoil indicated conformance of the test aerofoil as a profile for WT blades. The test aerofoil has the feature of easier manufacturability as against standard NACA0018 profile adopted in commercial WT blades. The studies conformed suitability of test profile at specified angle of attack with WT blade structure and hub construction using balsa wood. The choice of balsa wood was based on properties of lighter weight and adequate strength that was supported on the designed tower of tripod type. The designed WT system was for a rated power output of 75 W while operating at an average wind speed of 4 m/s. The system developed will be a feasible option for powering households in rural India.
Why did you choose to work on this project topic : Increase in the global warming and the over-dependance on fossil fuels to meet the energy demands has lead to increase in the global temperature and at the same time the grid based soulution is not feasible to the remote villages where off-grid soulutions and "envionmentally green" methods need to be supported in order to fulfill the consensus reached at the cop-21 summit at Paris where global warming and ill-effects in the long run was discussed.
Project Highlights : It focuses on integrating wind and solar energy to meet the energy demands of remote villages of India where grid based solutions are not feasible and the solution also focusses on using wood as a blade material for the blade which may provide better power output at a lower cost.
Institute/College Name: B.V.Bhoomaraddi College
City: Hubli
State: Karnataka
