  • desiging a series pass voltage regulator
    satiim
    Member
    Updated: Oct 27, 2024
    Views: 1.1K
    hey can anyone please tell me how to design a series pass voltage regulator???
    thanxxx in advance!!! 😀
  • Happy Chap
    MemberOct 15, 2010
    Hi Satiim, I see this post was a while ago. Are you still looking for help?
    Mike.
  • satiim
    MemberOct 16, 2010
    hey Mike.. yup i am still looking 4 help...
  • Happy Chap
    MemberOct 16, 2010
    Well mate, do you have a circuit in mind, or do you have to design it from scratch? I would be starting with an NPN power transistor rated at about 4 amps or more, Vce of around 50 volts or more, and there are plenty to choose from starting at under 50 cents. Then a couple of capacitors, resistors, a 1W zener diode for regulation, and one or two more small signal transistors for the current regulation.
    Then we have to look at the display system. I would be choosing a 3 1/2 digit LCD or LED module, with 0 - 200mV input, but that won't be "discrete components". It would be possible, no doubt, to use discrete componentry, but that is beyond my capability, and would probably need an enclosure the size of a mid sized kitchen cupboard, to accomodate the circuit boards and components. Assuming you can use an off the shelf module, I would combine two more ICs, a selector (can't remember the number, but in the 4000 CMOS family), and a 555 timer.
    What do you think? If you want to explore it further, we may get together online, on a conferencing site, so we can draw little pictures, and chat.
  • satiim
    MemberOct 20, 2010
    hey.. thank u! 😀
    well i have to build it from scratch...
    uhmm i'll be glad to get online and chat about it a little more! 😀 ... i just need to know around when u are usually online and have time! 😀
