@shivashish99-GRb733 • Oct 30, 2012
Manish TomarHow can you detect that the particular fuel injector is not working properly.??
i think we can make a setup of potential sensitive valve in series just before the injection of fuel and a temperature measurement(attenuation) inside the chamber .
@white-hat-RTFca6 • Oct 31, 2012
There are fuel injector testing machines.Fuel injectors are tested during your normal servicing, once in every six months.This is one way.
If a fuel injector is faulty then that particular cylinder will produce a different HP than other cylinders, this will cause vibrations. You can make out from the sound of a engine that if all the cylinders are working or not.
