Decide which one
You stand before 2 men that stand before 2 doors.
Behind one door is your freedom, behind the other your death.
One man tells nothing but the truth, one man tells nothing but a lie.
You cannot tell the men or the doors apart.
You are allowed to ask one man one question only.
You must now decide which door to open.
How do you decide which one?
  • ISHAN TOPRE
    @ishan-nohePN Jan 6, 2011
    case 1:Just ask any one man "What is 1+1?"
    If he is true man he will say 2.
    Then we will ask other(False man) which way can I escape?
    we will go with just opposite door.
    case 2:If first man replies any thing other than 2.
    We will ask other man which we have confirmed as true one"Which way to go?"
    and we will go with his dicision
    ๐Ÿ˜
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M Jan 6, 2011
    Good Answer.
    So, now assume that they are illiterate and they dont know mathematics or any general questions , try the answer now.
    @thebigk Jan 6, 2011
    Read that, folks.
  • ISHAN TOPRE
    We will simply change the question and ask"Is there freedom in one door and death in other?"
    The answer can be "Yes" or"No".
    The rest procedure being the same
  • Reya
    @reya-SMihdC Jan 6, 2011
    If both the men give the same answer we can know which door has freedom behind and which door has death behind!
    @abrakadabra Jan 6, 2011
    Anymore takers?
    Should I post the answer?
  • Reya
    No, dont post it!I will find the answer by tomorrow.
  • suyash
    @suyash-2N6gPP Jan 6, 2011
    Let's assign L to the person on the left and R to the person on the right. Let us assume door 1 is correct and door 2 is wrong.
    Now ask L a question that - "If I ask R as to which door is the correct one, what will he say? "
    Case 1 - L is a truth teller
    since L is a truth teller, he would know that R would give the wrong answer i.e. he would say door 2 and the same thing will be told by L to you because he just needs to answer truthfully what R will say
    case 2 - L is a liar
    since L is a liar, he would know that R would give the correct answer i.e. door 1. So when you ask L, being a liar, he would say that R would say door 2.
    Thus in both cases, you get the answer as door 2. You just go to the opposite door of whatever the answer you get !!
    @Suyash: That's a correct answer. ๐Ÿ˜€
  • ABLE1
    @able1-4DbgUA Jan 8, 2011
    Hello all, I am a bit of a newbie here. If I may interject that the question posted by "suyash" is incorrect. The analysis is correct but the question is not.
    The correct question should be as follows.
    While addressing one of the guards you would ask: "If I should ask your friend if that(pointing at either door) is the door to freedom would he say yes??"
    Sorry to rain on the parade. Hope ya'll don't hold it against me.
    Have a good day.
    ABLE1
  • shreyasm89
    @shreyasm89-jGobVm Jan 8, 2011
    ABLE1 is right!
