  • silverscorpion
    @silverscorpion-iJKtdQ • Apr 6, 2009
    whoa, you want us to debug such a long code?? What, is this your assignment or project work or something??
    Anyhow, I'm not too good with C++. There are some others who are well versed in C++ who may help debug this. But as far as my knowledge goes, you made a mistake in the class declaration itself. In the private variables, there's a variable called,
    char ***.
    This is not a valid C++ variable name. I see the same used in many places, and they are all errors. I don't know if it's a variable name or a triple pointer. Please check those. Other than that, I cant find any mistakes in the code. That seems to be the only error. Also, I executed the code changing the variables to "a" instead of *** and the compiler showed some errors in some loops. Take care of that.
    PS - of course, I didnt go through the full code thoroughly, there might be more errors there.
  • komputergeek
    @komputergeek-Yf5hJ4 • Apr 6, 2009
    @sanchitgulati:
    Don't delete the code even though your problem is solved.It might be useful for others.
    โ€‹
  • silverscorpion
    yep. You can't delete the thread.
    So, don't remove the code. Please put it back so that it might be of some help to the
    others.
    @thebigk • Apr 6, 2009
    Yep, don't remove the contents. They might be useful to others ๐Ÿ˜€
