@manish-r2Hoep • Oct 3, 2009
These file extensions are commonly used to show that a file is an image of a CD or DVD.
The most simple way to access these files is to use your CD or DVD Burner to burn them to a disk. Nero is a common program that is used to burn bin/cue files to hard media.
One really nice thing to do is to treat these files as a virtual CD or DVD without ever burning them. #-Link-Snipped-# is one program that is often used to do this. Microsoft now has a #-Link-Snipped-#
The other place that *.bin files are frequently used are in emulation software. Gaming roms are often stored in compressed files full of bin files. If you have a zip file full of *.bin files, try #-Link-Snipped-# or some similiar emulator. -
@maro-Ce3knx • Oct 3, 2009
Disk images, try PowerISO.
@mahesh-E2tZ3t • Oct 3, 2009
These file extensions are commonly used to show that a file is an image of a CD or DVD.use your CD or DVD Burner to burn them to a disk. OR
treat these files as a virtual CD or DVD without ever burning them. Daemon Tools is one program that is often used to do this.*.bin files are frequently used are in emulation software. Gaming roms are often stored in compressed files full of bin files. If you have a zip file full of *.bin files, try Mame or some similiar emulator. -
Also this link help you
<a href="https://www.weethet.nl/english/cdrw_usingnero_bincue.php" target="_blank" rel="nofollow noopener noreferrer">WeetHet - CDRW - How to write a Bin/Cue CD image using Nero Burning Rom</a> -
@sarveshgupta-txtmu5 • Oct 3, 2009
hey this the tech recipes info
but can you tell me how to do
for the emulator Mame or Daemon tool? -
It is because I dont have a cd or dvd rom
but i have a 4 part material which has 4 win rar archieve each consisting of a .bin and a .cue file
now i want to use it and open it
please help me -
hey dude I think Nero will help you to open it
do you mean to say that if i right click and say open with nero
then it will open -
@aashish-VrevFC • Oct 3, 2009
use daemon tools, free version available..check here : <a href="https://www.daemon-tools.cc/eng/downloads" target="_blank" rel="nofollow noopener noreferrer">Download DAEMON Tools for free - DAEMON-Tools.cc</a>
extract that file then open daemon tool,mount that image file in daemon tool
but i think as you said you don't have a CD/DVD drive then you can not able to mount that .bin,cue -
daemon tools create a virtual DVD drive on which the .bin/.cue files are mounted..you can specify the number of virtual drives to be created..
@arunaj-OPUrll • Oct 4, 2009
nand dont forget to select ALL SUPPORTED IMAGES while mounting using Daemon tools๐๐
@sarveshgupta-txtmu5 • Oct 5, 2009
Thank you guys
Working on your advice
lets see what's the result -
@as-nawin-adRdf9 • Oct 6, 2009
Burn .bin file without .cue file
To burn a bin file, you will need an appropriate cue file.
You do exactly the same as for iso files, but when you click on โburn image,โ you donโt browse to the bin itself, but instead to the cue file, and you open that one.
When the writer starts to burn, it will automatically search for the bin file and start burning it. In fact, the cue file tells the burning program where it can find the bin file that is attached to it. It is VERY IMPORTANT that you use the right cue file when you burn a bin. i.e both cue and bin files that are attached to each other must be located in the same folder, and every bin file has itโs own cue file.
Normally, when you download a bin file, you can download the appropriate cue file as well. If you do not have the cue file (or feel bold) you can make the cue file yourself, which is really easy to do:
a. Open notepad
b. Copy the folowing text into notepad:
FILEโnameofimageโBINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
Where nameofimage.bin is the name of the bin file you want ot burn.
c. The rest is easy: just save the notepad text with the name of the bin, but with the cue extension.
d. The file should be saved in the same folder as its appropriate bin file and should be something like myfile.cue -
@sarveshgupta-txtmu5 • Oct 20, 2009
This is the interface of the Daemon tool i have downloaded and installed
Now please help me with the steps i need to take in order to use and run a .bin file
Thank you![[โIMG]](proxy.php?image=http%3A%2F%2Fi541.photobucket.com%2Falbums%2Fgg400%2Fsarveshgupta%2FNewPicture2.jpg&hash=7fddfbae12aa05c41d9c6d3e5b3538c2)
@accoolaryan-BYyoWn • Nov 13, 2009
.bin & .cue files are cd images ,either you burn them on a cd using nero or instaall daemon tool by the way later is much better
use virtual device icon in your daemon tool and mount the file u want to use ok.
