  • DC to AC: Converting 9V DC into AC by inverter?
    navi shiv
    Member
    Updated: Oct 26, 2024
    Views: 1.1K
    is this possible CEeans 😀 a 9 volt DC voltage is converted to AC by usin inverter .......... ??? can it be stepped up to 230 volt usin step up transformer ???? is this process is feasible ????
  • Jeffrey Arulraj
    MemberOct 25, 2012
    Losses in boost converters will mount but it is very much possible
  • lal
    MemberOct 25, 2012
    Perfectly possible! Same like a 12V inverter or UPS works.
  • navi shiv
    MemberOct 25, 2012
    if this is possible can it be economical.......... ???? will the losses wil be more???
  • Jeffrey Arulraj
    MemberOct 25, 2012
    It is being used in some place but manufacturing cost I am not sure only a few components and so I think this will be Economical in the longer run
  • Festus Aladesuyi
    MemberOct 25, 2012
    Its much more possible even as low as 6v Dc supply and economical
  • Jeffrey Arulraj
    MemberOct 25, 2012
    But what are you planning to do with it ?
  • navi shiv
    MemberOct 25, 2012
    can it work wit house hold appliances 😀 ????
  • Jeffrey Arulraj
    MemberOct 25, 2012
    What the design ?😕
  • Festus Aladesuyi
    MemberOct 25, 2012
    navi shiv
    This actually depend on the Amp-Hour rate of the Battery, the amplification of the transistor or Mosfet uses and finally the transformer current rate
  • Jeffrey Arulraj
    MemberOct 25, 2012
    It is better to go with MOS I suppose as losses are higher in power transistors Don't think so #-Link-Snipped-#
  • Festus Aladesuyi
    MemberOct 25, 2012
    All u need in the oscillator section is an oscillation ic with Vcc 6v and transformer voltage 6v
  • navi shiv
    MemberOct 25, 2012
    amp hour rate of CAR battery ......is feasible ???
  • Jeffrey Arulraj
    MemberOct 25, 2012
    It depends on the load you are going to put in your design
    If too many appliances there will be some problem for low power devices that is enough
