dc motor graph
070790vivek
070790vivek
@070790vivek-09g1Yf Oct 25, 2024
i faced one problem while making the graph of speed control in dc shunt motor
it is- the speed of motor is variying between 1300 to1600 rpm.
i do not want to make graph from starting with 0to1600 rpm
can i break the scale ?
iam interested in making graph of speed on y axis from 1250to1650 rpm ?
is it possible/ if yes then how?😒
  • cooltwins
    cooltwins
    @cooltwins-I5yJpZ Feb 10, 2010
    it is generally not advisable to break the scale of graph in such graphs vivek 😀
    this comes out of my own experiance. 😳
    once i did it and then had to do it all over again
  • 070790vivek
    070790vivek
    @070790vivek-09g1Yf Feb 11, 2010
    i also faced same situation ,i break scale and have to do that all again
    but think if it is very high value and u need a clear information about the graph
    then if u don't break scale then the will be very short
    then what should be the solution?
    don't think about only your college copy as you are doing since childhood ,
  • Thesis123
    Thesis123
    @thesis123-GQniZl Feb 12, 2010
    if you are programming in MATLAB, the command is ylimit[1300 1600] after the plot command. Normally you should show how the motor speed is varying from the 0 to steady state including transient.
  • 070790vivek
    070790vivek
    @070790vivek-09g1Yf Feb 15, 2010
    but i even don't get my reply
    i want to find it on graph paper not on computer
    is there any way or not ?😡
