DC MOTOR CONTROLLED DOOR
gokuldas10
@gokuldas10-9j6ruo โ€ข Oct 26, 2024
Hi
its urgent
we are working on a project which needs to open a door model controlled by a dc motor.its a small project which is havin a 45rpm 9V dc motor.
IF U PREFER ANY IDEAS PLEASE HELP WITH UR REPLIES
No need of larger constructions. a simple one is appreciated.
we r also thinking on it
hoping for a good reply
thank you...
    @thebigk • Mar 30, 2017
    #-Link-Snipped-# - It'd be better if you could explain your problem a bit in more detail. What exact help do you want? What does your existing construction look like? What is the problem you are facing?
  • gokuldas10
    @gokuldas10-9j6ruo • Mar 30, 2017
    actually it is an automated door which uses a proximity sensor.The problem is that i have only one motor and i need to control the door with it
    gokuldas10actually it is an automated door which uses a proximity sensor.The problem is that i have only one motor and i need to control the door with it
    What what is the problem with operating a door with just one motor?
    Hint: You'll receive help quicker and better if you take out the time to describe your problem in depth. It helps us understand your situation so that we can offer help.
    @ramani-VR4O43 • Mar 30, 2017
    You need a torque to open a door. At 45 RPM the torque developed is decided by the wattage of the motor, which is not given. If no other mechanism can be added, you may or may not be able to open the door, especially if any friction or wind loads have to be taken into account.
  • lal
    lal
    @lal-R60Xjx • Apr 1, 2017
    What kind of door are you trying to use the motor with; sliding, conventional or what?
