DC generator equations
mibawad
@mibawad-hjwXTs Oct 26, 2024
Hello,
I am using DC permanent magnet motor as a DC generator. I would like to calculate the estimated output voltage and current from the generator at known speeds. I already know the armature resistance and inductance for the motor. Do you know where can I find the equation?
Many thanks
  • narayana murthy
    @narayana-z4W16q Jan 27, 2011
    i think this may help you
  • freak16
    @freak16-XgiLj6 Jan 28, 2011
    DC genarator are of various connections:
    1) Separately exicted
    2) DC shunt excitation
    3) DC series excitation
    4) DC componund excitation
    DC permagnet is considered as equivalent to dc separately excited motor
    considering the magnetism of magnet does not deteriorate with passage of time ( but it do go down with time) you can apply the equations for separately excited.
    As NM mentioned..
  • Arp
    Arp
    @arp-8yytsY Jan 29, 2011
    freak is right
  • mibawad
    @mibawad-hjwXTs Feb 1, 2011
    Many thanks for your reply. I would to know if I know the generator speed and the resistance and inductance values for the generator, and the back emf constant. Could I calculate the current and output voltage. I can't find this relation because I found that I have two unknown (I and V) in one equation. Is there two equations to calculate them.
  • narayana murthy
    @narayana-z4W16q Feb 3, 2011
    generator speed can be known from name plate details as i know
    resistance and inductance can be calculated from v and I equations
    I can be known from ammeter which is connected at output side
  • freak16
    @freak16-XgiLj6 Feb 3, 2011
    DC machine does not have inductance as far as i know.
    We use the equation for generator
    E (induced emf) = Vt(terminal voltage) + Ia * ra
    Where E is directly proportional to speed
    E = K w
    W= speed of rotor
    K can be found out from no of conductors parallel path and other parameters
    Let me know if problem persists
  • narayana murthy
    @freak: thanks freak iam forgotten as iam seeping about DC machines so i mentioned that
    @mibawad: yes freak is right there is no concept of inductance in DC machines
    inductance and capacitance only appears in AC machines because there is no alternating current in DC machines
    inductance only appears at only there is a existence of alternating current
  • mibawad
    @mibawad-hjwXTs Feb 7, 2011
    @freak
    What I want to say that for DC motor or generator:
    Emf=V+Ia*Ra+La(di/dt)
    Emf=K*w
    If I know K, w, Ra and La, and I want to calculate V and I according to the speed w. I couldn't from this equation because the number of unknown is more than the number of equations.
  • freak16
    @freak16-XgiLj6 Feb 7, 2011
    Will dce machine is having inductance i strongly doubt..
    And you need to know amout the load somehow..
    you cant absolutely..
  • narayana murthy
    @narayana-z4W16q Feb 7, 2011
    freak is right we have no inductance in DC machines
    E=V+(I*R)
    there is no inductance
  • mibawad
    @freak
    Therefore, I couldn't calculate the current and voltage generated from the DC generator without knowing the load as well. Is that what do you want to say?
  • freak16
    @freak16-XgiLj6 Feb 8, 2011
    @mibawad
    Yes buddy.. i am saying the same thing..
    And without knowing supply voltage as well as load no engineer of world can do it..
    Kidding😎
  • mibawad
    @mibawad-hjwXTs Feb 8, 2011
    But, there is no supply voltage for generator. It is only in case of DC motor
  • IES
    IES
    @ies-SMb0Go Feb 11, 2011
    @freak: Yes there is inductance associated with the coils present in parallel paths,
    which produces Reactance Voltage.
  • lal
    lal
    @lal-R60Xjx Feb 14, 2011
    What about this eqn : E = (fi)*Z*N*P/(60*A)
    Fi - flux
    Z - no. Of conductors
    P - parallel paths
    A - its value depends on winding. Eg: 2 for a simplex winding
    This is the induced EMF. To get the terminal voltage the armature copper loss is subtracted. (Assuming its seperately excited)
  • ganeshbalasti
    @ganeshbalasti-jOBcyb Jul 15, 2015
    [​IMG]
  • Akshay Singh
    @akshay-PN0kDM Jan 17, 2016
    I am thinking to build a generator with both rotor and stator rotating in this way relative speed between rotor and stator I.e N increase hence more electrical power
  • Akshay Singh
    Anyone online please help
  • Akshay Singh
    What no one answer here
