    @abhishek-fg9tRh • Dec 24, 2012
    Well yes tmp .vbs script is solution.
    Check - superuser.com/questions/455364/how-to-create-a-shortcut-using-a-batch-script
    PS : add http or www as prefix of link if it doesn't work.
  • grsalvi
    @grsalvi-7IhIh1 • Dec 24, 2012
    If you are thinking of making a setUp file. Use winRar , and compress the ".exe" file to SFX.
    In SFX ,there is also an option where you can tell to add shortcut and the location it should be placed.
  • Vishal Sharma
    @vishal-pysGmK • Dec 24, 2012
    I used Uharc to get .uha file...
    and then extracting .uha accordingly in a particular drive but it seems a little complicated..
    I got the shortcut using vbs but still, extracting .uha at the place where i want is a pain!! :/
