  • Create GIF Image From Video File.
    Abhishek Rawal
    Abhishek Rawal
    @abhishek-fg9tRh
    Updated: Oct 18, 2024
    Views: 1.2K
    Creating GIF Image from video file is quite simple.
    What we will do ?
    We will use screencast application like Kazam to record the on-desktop video. Then we'll use mPlayer to capture the jpeg screenshots & then finally we gonna use Imagemagick to convert those jpeg images in GIF.
    Tools Required :
    - Any Screencast application (I prefer Kazam)
    - mPlayer
    - ImageMagick
    - Linux based distro
    Steps :
    1) Install required tools[kazam, mplayer, Imagemagick] using apt-get (Debian/Ubuntu), zypper (Suse), pacman (Arch), yum (Fedora) ,etc..
    2) Record the screencast & save it in directory (We'll use 'Videos' for simplicity)
    3) Open Terminal & type :
    mplayer -ao null <name_of_video.extension> -vo jpeg:outdir=mygif
    4) Here we have used output directory as 'mygif' so a folder named 'mygif' will be created which will contain jpeg image of each & every frame of the screencast. Now, we will use those jpegs to convert it into gif.
    - Open Terminal & type :
    convert <output_directory_name>/* <desired_name_of_file.gif>
    Example :
    convert mygif/* mygif.gif
    - Have patience, it will take couple of minutes in transcoding
    5) You can optimise the gif & reduce the file size using 'gifscale'
    Open terminal & type :
    gifscale -O <original_file_name.gif> -o <optimised_file_name.gif>
    Example :
    That's it 👍
    AdministratorMar 19, 2014
    This convert thing is inbuilt into linux or you get it with mplayer?
    Create video using Kazam.
    mplayer converts video into jpeg screenshots of each frame.
    Imagemagick converts those jpeg into gif.
    It's done using combination of three tools which are easily available in all distribution's repo.
