Crack and Water leakage
pandianrajendran
@pandianrajendran-Q7aq3q โ€ข Oct 26, 2024
HI ,
my house roof crack and Water leakage issue photo attached. I need some solution from engineers. Basically I am electrical engineer. Any one suggest some idea.
  • pandianrajendran
    @pandianrajendran-Q7aq3q • Feb 3, 2017
    some more pic
  • Abderrahmane FARES
    @abderrahmane-fares-sgPrQQ • Feb 23, 2017
    Hi,
    Does your roof have any damp proofing below the stones or there is only the slab ? Because the leaks seem very big .
  • KSS Manian
    @kss-TLq9Kp • May 19, 2017
    pandianrajendranHI ,
    Hello,
    I think that the cement plastering in brick wall is the culprit. These cracks due to some poor mortar ratio and improper curing.
    Also I don't think that your slab is an issue. Because before laid tile's on the roof builders might done the weatherproofing. Also i see the seepage occurs in your wall & slab intersection.
    Confirm whether this water leaked wall is exactly below the wall were cracked? In that case I would recommend you to chip of the damaged surface and redo the plastering.
    Is your building is made by brick masonry (or) Concrete beams & columns?
