@thebigk • Mar 14, 2013
Mechies, we've an unanswered question. Tagging #-Link-Snipped-# and #-Link-Snipped-#. Over to you, folks 😀
@zaveri-5TD6Sk • Mar 14, 2013
question is not clear.
do you mean to ask, how fresh water will cause corrosion in i.c engines ?
if that is so, then how will fresh water enter this machine in the first place ? which part of it, will it come in contact with ? specify.
but even then it sounds like differential corrosion. -
@atul-namdeo-1tThXM • Mar 21, 2013
by mixing ethanol with water we can avoid corrosion in cylinder walls...
