  • Cooling using earthen pots.
    zaveri
    zaveri
    @zaveri-5TD6Sk
    Updated: Oct 25, 2024
    Views: 1.6K
    We all know that drinking water can be naturally cooled, if stored in earthen pots. This is because the pots being porous in nature, allows the passing air to penetrate through it, and cool the water, contained in it.
    Now consider that if a fast rotating table fan, is placed beside such a pot, filled with water, and is blowing all its breeze on the pot, then will the rate of cooling of water increase ? or will it cause the water to evaporate ? what exactly will happen ?
    I don't think it affect evaporation to a great extent and placing a fan would increase the cooling of pot water
    zaveri
    It is the reverse process actually.The pot being porous allows the water to 'sweat' out of the pot. If the surrounding air humidity is less than 100%, the water evaporates.The latent heat of vaporization has to come from the pot of water which cools.
    The principle is identical to the working of room coolers.
    <a href="https://en.wikipedia.org/wiki/Evaporative_cooler" target="_blank" rel="nofollow noopener noreferrer">Evaporative Cooler</a>
    Yes, keeping a fan blowing on the pot will cool it faster. However, the final temperature will be decided by the RH% and so the fan will not cool it to a lower temperature.
