Cooling tower
15081986
@15081986-NfyBWk โ€ข Oct 23, 2024
HI GUYS ๐Ÿ˜‰
I am a student of mechanical and want to know regarding the design of cooling towers as i have to use it in my final year project.
Please help me out with any kind of suggestions,sites or in any other way.
Thanks you All
๐Ÿ˜›
    @thebigk • Mar 13, 2009
    I guess CEans would be happy to help you if you ask specific questions. What are the difficulties you are facing in the design of cooling towers?
  • gohm
    @gohm-F3UUpP • Mar 13, 2009
    Yes, please ask specific questions. I have some experience with cooling towers and would be glad to help.
  • mechengine
    @mechengine-KgO48A • Mar 13, 2009
    cooling tower efficiency calculation
    im a 3rd yr mech engg student in an anna university affiliated college at
    Nagercoil in TamilNAdu
    im doing "fabrication of cooling tower" as mini project
    the tower possess "mechanical draft cooling system"
    I want to calculate the efficiency of cooling tower
    pls help me to find a soln๐Ÿ˜•
  • gohm
    @gohm-F3UUpP • Mar 14, 2009
    Do you already have your data for the calculation?
  • mechengine
    @mechengine-KgO48A • Mar 14, 2009
    i dont knw wat are readings that is to be taken from the cooling tower 4 efficiency calculation??
  • gohm
    @gohm-F3UUpP • Mar 15, 2009
    You will need the following data:
    cooling water flow rate
    cooling water inlet temp
    cooling water exit temp
    in air wet bulb temp
    in air dry bulb temp
    exit air wet bulb temp
    exit air dry bulb temp
    then you will need to calculate the following:
    waterside actual heat load
    in air wet bulb absolute humidity
    in air dry bulb absolute humidity
    % of saturation
    enthalpy condition at inlet & outlet
    calculate air flow on heat load of enthalpy condition
    calculate heat needed for evap
    This will get you started...
