  • Converter pins
    Laramite
    Member
    Updated: Oct 26, 2024
    Hello mates,
    I have cell phone charger and Laptop charger which I got from India and its specs are like some 220 v 50Hz, with 3 round shaped pins. Now I got it to USA and I was wondering what kind of converter do i need to use to get it work, since the kind of plug point used here is different than in India.
    Thank you,
    Laramite
  • Saandeep Sreerambatla
    MemberJan 18, 2010
    The converter which you buy should convert the input you get from your mains to 220V and 50HZ.
    So what is the output at your home?
    for example if it is 200V and 60HZ , buy a converter which converts 200V 60Hz to 220V and 50Hz.
  • Laramite
    MemberJan 18, 2010
    Thanks SreeRam, I think you gave me some idea that I wanted.
    Actually the output specs are 120V 60Hz from the mains and the input to the appliance is 230V 50Hz. So you mean I need to get a converter thats converts 120V 60Hz to 230V 50Hz. But I wonder what do you call that gadget? Is that a step down converter or is there any other gadget that does the job.
    MemberJan 18, 2010
    Thats a Step up converter!
    I guess you can get it!!
  • Codes Guides
    MemberJan 19, 2010
    You can get a step-up voltage converter to convert the USA 120V to UK 220V. But you may find it's easier and/or cheaper to just buy another power adapter for your laptop. You should be able to easily get one that will accept 120V AND 240V, i.e. an international adapter, as most laptop/cell chargers these days will accept 110V - 240V.
    - CG
  • rasu3045
    MemberJan 29, 2010
    Every place (country)has different socket So you need to buy multiple socket pin which is applicable for different country socket as well as connect power cable also
